New 12v batt, old immo problem...
  • fzr phil
    • Sep 2006
    • 153
    Hello everyone
    I still have my 2.8CQ, it is 2 years now since the gearbox failed but i can not bear to let the car go for scrap or be stripped bare. working now for johnson controls company car (zafira-)
    So.
    Finally got a new 12V, but still have the car-no-start problem. mine is MY95, and has the dealer fitted dongle plug-in immo along the steering column.
    the car will not turn over on the key, though i am sure the ign immo (key one ) is ok, as the dash light goes off. i get all the fuel pump whirring noises.
    (if i remember) the procedure is:1) ign on..(beep), .2) put in (take out) immo dongle...(.more beeps), 3) turn key and car starts.
    now, when i '2' put in the dongle, i am not getting any further beeps , and nothing happens to turn over the car.
    i just want to start my car!
    i live very close to http://www.specialisedengines.co.uk/index.htm and have had a chat with a guy there the other month. Maybe they could do the gearbox for me, but obviously, i need to get the car started. i talked about the immo problem with this guy, but so far thats as far as it got, he hasn't had a look yet.
    can i fix it myself?
    thanks in advance. also, if anyone knows somewhere else i could trust to do my gearbox, would be grateful.
    all the best
    Phil
    95' 2.8E Coupe quattro pearl blue
    97' A3 1.8T Sport Auto Silver
    95' Yamaha FZR600R
  • Phil Payne
    • Jul 2009
    • 328
    When you try the starter, are there any volts reaching the copper bridge in relay position 8 in the fusebox?
    If no - problem is inside the car and may be the immobiliser.
    If yes - problem is in the engine bay.
    • fzr phil
      • Sep 2006
      • 153
      thanks,
      i will confirm this.
      at first, the car was starting ok every so often with jump leads, but after a few months as the batt died, one day it just wouldn't turn over.
      95' Yamaha FZR600R
      • mcandmar
        • Apr 2004
        • 5118
        My moneys on the aftermarket immobiliser, i have seem some where they have a master dongle key, and all the others need to be programmed for the immo unit if it has been unpowered for a while. Usually the master dongle is red or marked differently.
        If the factory IMMO key isnt working the engine will still crank over but you will have a light on the dashboard with a key symbol on it. No engine cranking smells of after market IMMO to me.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • fzr phil
          • Sep 2006
          • 153
          I checked that copper rail in the fusebox, definately no voltage on it as i turn the key. AMD technic are local as well nr lakeside, so guess i have 2 places to try.
          i have the next week off, so would very much like to get it started.
          thanks again
          philip
          95' Yamaha FZR600R
          • Tonks4x4
            • Nov 2005
            • 3062
            Philip save yourself future hassle and take the immob off altogether. You will probably find that there is only 2 points of immobilisation.
            No.1 on the rear of the ignition barrel the red/black wire will have been cut. If you cut these 2 connections to the alarm and wire the original audi loom back together it will crank again.
            No.2 the feed to the fuel pump will have been cut. Again find this join usually along the passenger cill area and wire the original audi loom back together it will stop the alarm from cutting the fuel pump
            Audi Nut!!!
            • fzr phil
              • Sep 2006
              • 153
              thanks!
              that would make a lot of sense.
              i always found that push in immob a hassle, and, the grief when i had to get a key coded after losing my set the other year......
              95' Yamaha FZR600R
              • gripper
                • Jun 2008
                • 1156
                Got a picture of your 2.8CQ Phill ?
                Always curious when V6 quattros appear on here
                Even more so when its one that's a similar colour to mine
                For what this cost me so far I could have bought an S2
                • fzr phil
                  • Sep 2006
                  • 153
                  post #747 and #748
                  few years ago, but it doesn't look much different bit dirtier perhaps, lol
                  95' Yamaha FZR600R
                  • fzr phil
                    • Sep 2006
                    • 153
                    It Works!
                    i got it started!
                    thanks everyone for your advice, i did talk to the guy at specialised too, and he suggested the same.
                    i got to the wiring, cut out the immobiliser and reconnected the loom back together,
                    the car started after about 3 sec's of cranking
                    will leave the key circuit in place for now.
                    regards
                    Phil
                    95' Yamaha FZR600R
                    • Tonks4x4
                      • Nov 2005
                      • 3062
                      Good stuff....
                      Audi Nut!!!
