Considering he took out the dash, the problem is most likely somewhere in the wiring.
A simple continuity test with a multimeter on these might show the problem:
Test ECU PIN 49 to G28 (Speed sensor) signal pin
Test ECU PIN 47 to G4 (Crankshaft position sensor) signal pin
Test ECU PIN 48 to G28 GROUND pin and G4 GROUND pin.
Make sure ECU PIN 49 is not short to GND (measure resistance between PIN 49 and chassis).
