Demetri
What does a "if there is no fuel pressure taper" mean.
Embarrssed, forgot to include that macanmar fitted a 044 pump to the car a while ago while the block was with JP. I've gone back and added it to the spec list post.
Can I use the std S2 ABY fuel presurre regualtor or does it need to be changed and to which one / part number ?
Clutch is a South Bend Stage three one with a metal face on one side and an organic side on the other, Marc in EFI Express would be able to confirm the exact one if he reads this thread ?
Note what you say about the K26 / 3071 hybrid, but interested to know why you don't recommend them ?
You're right about the Wagner Exhaust manifold, the one I have is for a kkk, so would have to swop it for a T3 one.
Presumably even though 034 are dearer, they would be able to supply the correct new lines kit for the 3071 ? Or is there someone in the UK to contact ?
Would probably cut up an S2 air box to work with the 3071, couldn't cut up an RS2 airbox. Or use a non oiled cone filter and some ducting to "fence off" the cone filter from the rest of the engine bay.
"you will need a maf-turbo hose with bigger opening for turbo", where would I get one of these ?
