Not boosting!!
  • nick92S2
    • 56
    Not boosting!!
    92 3B - Homefry.
    Help needed again please!!
    I had a huge boost leak - I could hear pressure escaping from a split hose and when the clutch was pushed in it sounded like I had a huge dump valve and the car would only rev to 5000 rpm. I have now replaced the accordion hose to the side of the head light and all the small bore hoses running around the engine bay, fitted a new dump valve, and fitted a hose around the 'o' ring on the intercooler, the car revs freely but rather than boosting to 1.5 bar I am only getting 1 bar - can anyone help.
    Check your WGFV and clear your fault codes on the ECU and give it another go.
    • nick92S2
      • 56
      Cheers Greg,
      I realise this may be a stupid question to many of you guys - but where is the WGFV? and how do I clear the fault codes?
        Waste Gate Frequeny Valve. Its the N75 valve with 3 boost connections fitted just above the diverter valve. This controls the amount of overboost you can have.
        to clear the faults open your fuse box, there should be a little red cover over 2 fuses saying 'moteur' take this 2 fuses out for a couple of mins the refit.
        • nick92S2
          • 56
          I have ordered a new WGFV from VAG parts £44 - I figure it's 12 years old and could do with replacing.
          Thanks Greg
          • nick92S2
            • 56
            Forgot to ask - does the WGFV have a fuse, I looked in the fuse box under the bonnet and could'nt see it?
            I also noticed a relay in the fuse box with terminals in the top for a fuse, but mine has not got one fitted, should it have, if so what rating???
            Thanks
              One of the auxiliary fuses includes the WGFV - F24 from memory !
              Paul
                thats one hell of a memory you've got there paul, or maybe you've spent a little bit too long working on the S2. lol
                • porkkis
                  • 1994
                  Actually there is a fuel pump relay feed for most of the engine contol components, inclufing the wgfv, maf, lambda probe warming etc etc etc
                  • audiman
                    • 4827
                    I dont think that a homefried 3B should be boosting to 1.5bar anyways?? Thats more than a stock RS2. I might be wrong. After changing all these parts, does the car go any better? Is it still making the 'whooshing' noise?
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                      My 3B, with just the homefry, showed about 20lbs on the gauge which converts to 1.378951 Bar
                      • nick92S2
                        • 56
                        The WGFV has not arrived yet, but the 'whooshing' noise has gone and throttle response feels much better, just need to find out why it's not boosting as it was......
                        • nick92S2
                          • 56
                          I have now replaced the WGFV and am now back to full boost (1.5 bar) After replacig these parts the car is much quicker and more responsive, I rekon it must have had a boost leak since I have owned it.
                            1.4bar is about right for max boost on a homefried 3B or ABY - of course it tails off to about 0.9 on the redline cos the wee compressor can't take it.
                            Paul
                            • audiman
                              • 4827
                              Glad its sorted. Makes you just wanna go drive it again(hard)
                              Audi UR Quattro
