RS2 turbo max torque
    Right I've been searching for half an hour now, I'm sure this information must be on the fourm but I can't find it for the life of me
    Loads on informaiton on the max hp, and lots of comments on the RS2 turbo being a torque monster - but what is the realistic max torque that it will produce, bottom end permitting?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    in my car i did 644nm...and 391hp, 2.0bar as a peak holding it and at around 5200 rpm its drops to 1.5bar....and then less and less
    it was my last 3B setup,and of course i think that these numbers are too much optimist....because normal power on RS2 turbo should be around 360/370Hp with RS2 Injectors,because they are maxed for sure
    anyway i think that 600nm could be true
    never had a problem with torque in my OEM 3B bottonend ,the same as my 3B hearbox first and now a ASZ coupe quattro Box
    • prj
      • Mar 2010
      • 6308
      This is such a rigged question...
      How much torque it will produce depends on boost.
      To bend rods you need 2.3+ bar with heavy knock.
        what do you mean a rigged question?
        I just want to know roughly what torque the RS2 turbo will produce when mapped aggressively for maximum torque..
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          i would say 600nm, more or less i think, dont worry with Prj,he is just kidding
          if everything is running fine in your car i would say dont worry too much with the RS2 turbo,only based in my personal experience of course
          -Tomas-
          • T2Andy
            • 1903
            My RS2 HYBRID did over 400lb\ft@ 1.7bar ,very lively
            • prj
              • Mar 2010
              • 6308
              Upto 700nm if run to crazy boost levels.
              Normal aggressive map - 550nm.
                thanks... so next question, by crazy boost you mean 2.3+bar as you mentioned above?
                With the appropriate injectors and mapping to prevent knock, & uprated rods for peace of mind, how long would the turbo last?
                • prj
                  • Mar 2010
                  • 6308
                  Long.
                  No need for uprated rods at all on this thing.
                  Seriously, my friend ran the thing at 2.5 bar for half a year with crazy knock and only two rods were slightly bent.
                  With proper mapping - forget rod upgrades.
                  RS2 turbo is too slow anyway
                  Coming out with a K26/K27 turbo kit soon (turbo, injectors, spring, tune, price in the 1300 gbp range).
                  • avants2turbo
                    • Feb 2008
                    • 1287
                    mine makes 400lbsft 1.9bar, that was with a stock aby dp
                    • Avantus
                      • Sep 2007
                      • 941
                      • Country: Belgium
                      Keep us informed. To be done on stock compression rate?
                        Long.
                        sounds good valve for money
                        I'm dreaming of 700+nm with fastest boost response, lowest lag possible
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          you want a S1 EVO 2 then
                          • prj
                            • Mar 2010
                            • 6308
                            If you want it reliably...
                            GT3076R, Big MAF, 600cc+ injectors, rod upgrade...
                            Will give you 700nm all day and work perfectly
                            BTDT.
                            Alternate possibility: HX35 Super with KKD manifold...
