Ahh oki just looked like the crimbing style connectors on the pictures.
But I think your main problem is the ground on the shaft. A quick check to see if that is the cause of the problem would be to ground the single wire to the camcover instead of the shaft that holds the coils. Then check if you get spark and if you do then use +12V from 3B coil plug as suggested above and appropriate ground for TTL low.
