Head rebuild and Manifold conversion complete
  • mcandmar
    • Apr 2004
    • 5118
    Finished my head rebuild this evening, I've only gone for a short test drive and it runs so silky smooth, sounds great
    Rebuild piccys, http://www.cr-x.org/cq20v/manifold/
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • NoNonsense
    Forum Sponsor
    • Apr 2004
    • 673
    furking awesome! Great pics, too!
    Joe "NoNonsense"
    axis motorsport
    joe@axismotorsport.com
    • sps-si
      • Apr 2004
      • 107
      what a manafold!!!
      Simon.
      S.P.S. TUNING
      '93 ABY S2.... sold
      me thinks RR URQ next :mischeif:
      • Sweeper
        • 1317
        • Country: Latvia
        HM , I could be wrong but I have the same manifold on my old 7A car. I thought it comes as original ????
        I still have it if it's so wanted.
        Vadim.
        • RIX
          • Jul 2004
          • 229
          • Country: Denmark
          it´s a work of art
          RIX
          • spink
            • 4382
            The earlier 7A's had the tubular manifold, makes a decent improvement and doesnt crack as easy as the other one.
            • mcandmar
              • Apr 2004
              • 5118
              88-89 had the tubular, 90 onwards had the crappy cast version. I found specs on a German website that spec’s 170bhp for 88-89 and 164bhp for 90 onwards. Interesting that Audi actually published the difference.
              Did a second test drive today and it gets really hot with that manifold, so hot it melted the small crank case breather pipe
              Next project is to find an early intake manifold to mount the proper heat shield for it..
              • 90quattrocoupe
                • Nov 2003
                • 771
                I did the same to my coupe a coupe of years ago. Replaced the exhaust with the earlier header. I P&P the head and I am running 272 cams. I have a late 1990 and the upper heat shield bolt right up. They must have changed the design on the intake in 1991. I like the way it runs. Of course, not a whole lot of power gains, but doing the head and the exhaust made the car a lot smoother and pulls all the way to redline.
                Then again, I have an S6 motor sitting on the floor of the garage.
                You will find that the warm air intake on the airbox will not line up anymore. If you live in a cold climate, you may want to pick up the earlier warm air intake. The airbox is the same, just the intake is a change out.
                • Stick Insect
                  • Dec 2003
                  • 2338
                  [QUOTE=mcandmar]88-89 had the tubular, 90 onwards had the crappy cast version. I found specs on a German website that spec’s 170bhp for 88-89 and 164bhp for 90 onwards. Interesting that Audi actually published the difference.QUOTE]
                  my 1990 CQ20v has a tubular manifold. I understood that the 2wd 20v cars had the cast manifold and this was the case on a 1989 2wd car I broke up. Still got the engine. I thought the quattro had a bit more power to make up for the drivetrain losses.
                  I don't know if this image of my CQ20v engine bay helps, I just took it.
                  David
                  • audiman
                    • 4827
                    That manifold looks well trick. Cant beleive its a stock item :O Just looked it up on ETKA its £854 +VAT Dont go breaking it.
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • audiman
                      • 4827
                      That manifold is for engine code NM and is not listed for 7A. But that engine bay, David, is looking well tidy. Im not all that up on my 20V non turbo engines so im not sure which engine was fitted to what. Just going by what ETKA lists
                      Audi UR Quattro
                      • Stick Insect
                        • Dec 2003
                        • 2338
                        Thanks Tom, I have spent a bit of time sorting it, the biggest job was removing the waxoyl to sort things out ( it will be going back on soon though!) My car had the manifold on when I got it with 7K miles on the clock, it has only done 22k now at 14 years old!.
                        I'm sitting here fixing computers ( and posting in between ) and I'm not getting on with my Audi.
                        David
                        • martinjs
                          • 3205
                          have you got them brakes fitted yet david??
                          martin
                          • spink
                            • 4382
                            Ive just stripped a 1990 20v 90 q and a 2wd 20v auto j plate, both had the cast version.Both were cracked as well.Still got plenty of bits left if you need any.
                            • mcandmar
                              • Apr 2004
                              • 5118
                              Looks like you have an early model, nice tubular manifold & ISV mounted on the airbox. Odd the 2wd was a cast
                              The two mounts shown marked in the piccy are not on my manifold, has anybody got an early intake manifold they want to sell ?
                              Thanks,
                              Mark.
                              P.S. Your car looks like new!
                              [QUOTE=Stick Insect]
                              David
