My RS2 has a slightly lumpy idle, but drives beautifully otherwise and goes as it should. It just misses ever so slightly on idle every second or two. 135000 miles, it was doing it before and after the recent cambelt renewal and changing the spark plugs has made little difference. Fuel consumption seems about right, ie heavy around town and late 20s mpg (uk gallons) on a run. I just know it shouldn't do it and am out of ideas.
Lumpy Idle on RS2
@herald... do you have vagcom / vcds ?
if so then we can learn some more by looking at certain logs.Paul Nugent
Slight misfire at idle = bad coil or pos channel.Comment
or even the Coilpack boots, although this tends to show up at higher engine loads.The Perfectionist
