How do you check the fuel pressure on an RS2 ?
How do you check fuel pressure on RS2
Ummm....with a fuel pressure gauge, Tee-d into the fuel line, using an adapter like the one from 034?
http://www.034motorsport.com/fuel-in...etc-p-499.html
94 UrS4 V8 6 spd manual avant -
And to pre-empt the next question... on an RS2 ... you should see 3.8bar +/- manifold pressure on the fuel rail
so at 0.5bar vacuum on idle you get 3.3bar on the fuel pressure gauge
and at 1.5bar boost you should see 5.3bar on the fuel rail... this is pretty tricky to prove of course unless looking under the bonnet at a dyno for example... unless you have an emulator and a hand pump to fool the ECU into letting you idle with silly high fuel pressure.Paul Nugent
