Smokey question
  • powaw
    • Jul 2009
    • 80
    Smokey question
    I'm thinking about installing a restrictor in the supply line of my turbo and want to hear your thoughts and personal experiences.
    Stock AAN with Holset hy35. The supply line is a -3 an. When the engine is cold the oil pressure is about 96 psi and I get a nice fog machine effect from the exhaust. As the motor warms it diminishes. I'm thinking a restrictor could help cure the problem as I feel that it is the pressure pushing oil past the turbo seals. The turbo is freshly rebuilt. There seems to be a debate as to if the -3 line is already small enough. I read some posts though about a Holset not liking pressures above 60 psi. Some people claimed that a .070" restrictor was good for a rb25. I'm hoping that someone has restrictor experience with a Holset on an AAN. Thanks for the help
    currently: 1987 944 NA 5spd, 250 lb hyper coils, 27 mm t bars, Koni, 968 m030 bars, full delrin, Audi I5 20VT, VEMS, Tilton, EFI Express, Seimens, Race Technologies
    see the AAN/944 swap at Nina's 20VT
  • Billman
    • 4129
    can you send us a picture of four turbo to see how do you connect the line?
    Do you have a good thick oil return line?
    Go Holset or Go RS4
    • powaw
      • Jul 2009
      • 80
      I don't have a pick handy, but I was found in some receipts that it actually looks to be a -4 supply line and -10 return. All lines connect to the factory locations. My return goes to the port at the front of the block.
