5 bar oil pressure on start up?
  • Rikki Kitto
    • Feb 2010
    • 6276
    Soon as I start the engine I have full oil pressure 5 bar, is this ok? After about five minutes it settles down to 2 bar on idle 5 under load, which is what it used to read Any suggestions?
  • Dan
    • Jun 2008
    • 1242
    Perfectly normal AFAIK - especially starting from cold.
    1993 ABY Coupe | BMW R1200 GS
    A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
    • Rikki Kitto
      • Feb 2010
      • 6276
      AFAIK?
        those numbers are normal...
        • Dan
          • Jun 2008
          • 1242
          Originally posted by Rikki Kitto
          AFAIK?
          As Far As I Know
          (ie. not claiming to be an expert, just going off what mine does )
          • Rikki Kitto
            • Feb 2010
            • 6276
            Thanks guys, just getting a bit paranoid with all the things that seem to happening to my car lately
            • Bowlerwell
              • 1052
              Normal. Same as mine.
              John Bowlerwell
              Electronic Engineer
              Present:
              Nogaro Blue RS2 - TOE
              Previous:
              Kingfisher Blue S2 - UAA
              Volcano Black RS2 LHD - DEX
              • Colesy
                • Feb 2009
                • 2981
                How long should it take for the pressure to drop back to 2 bar? Been doing a lot of 10 minute runs recently and pressure is still at 4 bar at the end of the journey.
                • A80Avant
                  • 10873
                  • Country: Greece
                  its normal to be around 2bar on a full warm engine. If the engine is cold and the pressure falls to 2bar within 5 minutes, thats a bit odd, unless you have a very hot weather and the engine's coolant temp rises fast enough. it takes my car def.more than 5 minutes to reach normal temp.
                  • j_jza80
                    • Feb 2011
                    • 229
                    My oil pressure is 1.5 bar at idle when warm, is that a bit low?
                    EX S2 ABY owner, now driving a BMW E39 530D manual & a MK1 Golf GTi called 'Hattie'
                    My second Supra, a very special 1997 RZ-S 6 speed single
                    • A80Avant
                      • 10873
                      • Country: Greece
                      Should be fine. The sender gets worn with age. I changed mine recently and from 1.4bar on idle its now between 1.8-2bar
                      sent using Android
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Mine is now reading only 1 bar when warmed up on idle but still goes up to 5 when accelerating please tell me this is still OK
                        • A80Avant
                          • 10873
                          • Country: Greece
                          what oil are you using?
                          what is your idle rpm as well?
                          low idle rpm will bring the pressure lower. Thinner oil (10W30-0W30-5W40) depending on type as well, will make the warm idle drop as the flow of oil between the bearings is easier and therefore the reflected oil pressure is lower.
                          If the engine has done a lot of miles without any bottom end work, there could be a bit of wear there, but overall, if the pressure goes higher than 3bar @ 2000rpm, i wouldnt worry about it.
                          I would go for a 10W50 titan fuchs and that might make things a bit better.
                          • s2driveruk
                            • 12696
                            seeing the exact same on mine changing from a 10/60 to a 5/50. warm idle is about 1.6bar when previously it was bang on 2bar with the 10/60w
                            1992 3b S2 Coupe
                            • caterpillar
                              • 2480
                              remember the oil oilspecs are way to the better TODAY, then the 5pot was att the drawingboard ( pre1980) the oilpressure are ok; if you got over 7 bar when cold, i will high my eybrow... and 1,5-2 bar when hot at idle are also ok... under 1 bar att idle and may some rattle in engine, i will rebuild it.. and 300000 km on the audi 5pot are not problem either..
