Exhaust temperature. Slightly under 900 Celsius in exhaust housing. Should I worry?
  • NEO
    • Oct 2003
    • 326
    As the topic says... I have an ABY with RS2 stuffs and around 350 hp. I have a temperature sensor in the exhaust housing of the turbo and at max load I get just under 900 degrees Celsius in it. I have always thought this was to much and I have been super worried about it but today I was told it's probably OK. I thought I should check here what you guys say. Should I worry or not?
    /NEO - I have a sexual thing for big brakes.
    www.irry.com | Irry got a face lift!
    #nordicaudi @ irc.nordicaudi.com
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    900 is absolutely fine. YOu have room up to 950-970 on that area
    • NEO
      • Oct 2003
      • 326
      Ah. Glad to hear! And what should the temperature be in the other bits and parts? I mean if I should measure in exhaust manifold or downpipe.
      • JP
        • 1858
        Before turbo 950celsius after turbo 850 celsius are usually my main two marker points. Before turbo is more accurate as not having to account for heatloss in turbo exhaust housing. But is always a small risk of the tip dropping of and going through the turbo although usually they just melt away.
        UrS6 Stroker + HTA3586 =
        • Billman
          • 4129
          is it before the turbine impeller or after?
          Go Holset or Go RS4
          • NEO
            • Oct 2003
            • 326
            Just where the exhausts enters the turbo, so I guess that would make it before the impeller. =)
            • Billman
              • 4129
              Yep, you are ok there.
              Go Holset or Go RS4
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                i was having around 835Cº at 6000rpm measuring it around 7cm after the turbo
                hope it helps for you
                • aRtiS
                  • Nov 2008
                  • 989
                  • Country: Latvia
                  Does it mean, if EGT sensor is in down pipe, gas temperature in exhaust manifold (before turbo) should be considered ~100°C more?
                  Audi RS2 600 hp
                  Audi S2 1200 hp
                  MB 230E '83
                  https://www.facebook.com/ventracing.lv/
                  • NEO
                    • Oct 2003
                    • 326
                    thanks guys. you all just made my day, week and month. I was just out for a little ride and no matter how hard I push it it doesn't go above 900 so now I can finally sleep at night.
