Where to start.
Had this issue last year and thought it was due to the high intake temps and after fitting the water injection things appeared to have been sorted and with Paul's further tweaks to the ECU it has run exceptionally well until the last week or so when now and again it would feel as though i still had the handbrake on a couple of notches and early this morning (when it should have been at its best) I timed the in gear performance and have lost almost 1/2sec in second between 30-50 with no signs of it returning to its 'normal' form. Anyone had this and any ideas where to start. WOuld a faulty IAT sensor cause this as it's about the only sensor thats still original..
,you dont need a vat number.Although i do get a bit of discount but anyone off the street can buy from andrew page,try another branch
