Hi guys
This is something I have been thinking about over the years... How have you guys fixed your ECU up behind the glove compartment? Not only do you have a couple of A/C pipes there which I'm a bit afraid to kill but I'm also a bit scared that it might wear a hole on the water drain rubber hose connected to the evaporator. As seen here my ECU is more or less just stuck up between the A/C pipes and the glove compartment and the ear on the ECU is more or less resting on the previously mentioned rubber hose.
There's supposed to be some sort of mounting bracket for the ECU originally, right?
It would be nice to have a little chat with those german engineers over some of their choices back then,
