Oil cooler adapter removal from oil cooler pipes....
  • Ian Simmonds
    • Jun 2005
    • 2858
    Quite a hard one to explain really, but I've removed the oil cooler from the S2 ABY, and the male/male adapters (if that is the right description) have unscrewed from the oil cooler rather than the oil cooler pipe... Now as we stand, the pipes are still attached to the car and I can't shift the adapters off the oil cooler pipes to fit the new adapters (different size oil cooler bore diameter) so I can fit a bigger oilcooler.
    Any thoughts as to how to get these pesky things out the end of the oil cooler pipes without going bezerk...?
    Kind regards
    Ian
    93 MTMS2 Avant
  • westcountry S2
    • Jun 2011
    • 90
    Just done mine and the same has happened. All i done was to heat the nut up with the gas and they come undone but were tight all the way
    • S2 EDS
      • Feb 2011
      • 578
      I had a similar problem. In the end I used an open end spanner and a cordless impact wrench with a long socket on the end if that makes sense
      4 Rings Rule.......Everytime
      1984 80 Quattro B2 - Project Car
      1996 S2 - ABY 6 Speed - Pride and joy
      2003 A2 TDI - Economy
      • AndyP
        • 6049
        Undo the hoses at the car end, then you can get them in a vice and remove the adaptors?
        • S2 EDS
          • Feb 2011
          • 578
          See my pics
          Have a look at my photo album - documents mainly renewal and refit.
          • Al Wyn
            • Nov 2006
            • 3746
            Better get your skates on for sunday Ian
            S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
              I just used 2 spanners and squeeze
