If one wants to replace the rods on an ABY while it is still remains in the car, is it, take off the head and also the sump, but to be able to remove the sump, the subframe needs to come out ?
Anyone whose BTDT might post their advices or comments ?
Never done it myself, but im pretty sure at worst youd just need to loosen te rear bolts and remove te front ones and let it hang down to give you enough room to play with. Te bolts are pretty long.
After you hav lowerd the subframe ect... my tip is to remove the two bolts at the back of the sump that you need an extension to get at through the holes in the gearbox bell housing (if its the same as a 3b) can be tricky, have a magnet at hand or better magnetic tool head. but from there its plain sailing (until u go to put the first few blts back in...
