Keep getting code 561 in periods???
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    What causes this, Any ideas?
    Could it be the breather system that causes this?
    Car is s2 aby btw with homefries
  • A80Avant
    • 10873
    • Country: Greece
    if you search on the forum there is a large thread about that code
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Have changed maf and lambda to brand new original ones and code still activates.
      So two questians: could it be because of mé running 95 ron, or something Else?
      • bazburn
        • Feb 2010
        • 583
        2413 (Blink Fault Code), 00561 VAG1551/2 Fault Code Number
        Mixture Adjustment,
        Adaptation limit exceeded, Adaptation limit not reached, Leakage in exhaust system before 3 Way catalytic converters, Incorrect signal for Mass Air Flow Sensor, Spark plugs, ignition coil(s), or Ignition Coil Power output stage malfunctioning
        Symptom: Rich mixture, increased fuel consumption
        Hope I'm not teaching granny to suck egg's...
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          Mixture Adjustment,
          Hmm ign. Amps are brand new hella one's, coils are brand new oem ones, exhaust is leaking but ón outlet side of catalyst.
          Problem seems to comeback when i go 100% throttle and not so much when ón part throttle????
            • veneto rs2
              • Jun 2006
              • 1022
              • Country: Veneto
              MAF connector cna easily be the problem like newsh linked
              I got rid of that 561 faulty code that was keeping coming out randomly (sometimes alone sometimes together with the 537 lambda one) by changing ALL the vacuum tree pipes and hoses and bits and pieces behind the thorottle body.
              Plus all the PCV pipes and bits and pieces including the flame trap.
              Nasty job but going trough all the connections there makes you understand how easy it's to get unmisured air in your motor and by this having that code as result.
              Stefano
              http://www.audisportclub.com/
              • AUDIS2avant
                • Jan 2009
                • 670
                • Country: Denmark
                Thanx m8.
                I have changed the plug and connectors but only 5cm of wire but no help, Will check the wire to the ecu just to make sure.
                • GT500
                  • Jun 2006
                  • 2181
                  Don't forget to measure your fuel pressure.
                  Rob..
                  87 UR 20v ABY
                  97 S6 Avant
