Hi All
I've got a strange thing going on with the WGFV actuation on my 3B. It seems to work ok with a stock valve but when I try a heavy duty valve I get no boost control, only spring pressure. I've tried with 2 different (S2 Bo type) HD valves and no joy. I've blown through the valves, operated the solenoid with a 12v battery and checked the correct operation and flow a few times and I'm sure everything is correct. Swapping back to an old stock valve works fine and I get my full boost back. It seems like maybe the ecu is not supplying enough current to open the HD valve..
Any ideas?
I think the WGFV gets a 12v feed and gets grounded by the ECU to actuate, is this correct?
Any ideas?
