Why does my car go like f**k when its cold and lose power when it is hot?
I am reaching the end of my tether with this problem now and begging for advice.
I've replaced the fuel pump, the FPR, N75 valve, the coolant temp sensor on the back of the head, i've changed the barometric sensor, and the ECU has been to S2Central.
I'll get a rotor and cap during the week but i dont expect much from that. Plugs are Bosch and good condition, leads are new and tested. I haven't performed a boost leak check yet. But waiting for a reply from Andy P.
What else can affect the car's performance as it warms up? Its a 3B.
Any input would be greatly appreciated. Ive stuffed it in the garage now, out of my sight in disgust.
I've replaced the fuel pump, the FPR, N75 valve, the coolant temp sensor on the back of the head, i've changed the barometric sensor, and the ECU has been to S2Central.I'll get a rotor and cap during the week but i dont expect much from that. Plugs are Bosch and good condition, leads are new and tested. I haven't performed a boost leak check yet. But waiting for a reply from Andy P.
