Engine running to rich after comporession drop?
  • blackS2
    • Apr 2010
    • 455
    deleted
    [__]=oooo=[__]
  • blackS2
    • Apr 2010
    • 455
    deleted
    [__]=oooo=[__]
      was the car remapped? as the ignition timing will need to be advanced to compensate for the compression change
      • QuattroFever
        • May 2006
        • 1360
        very strange.
        Fuel pressure changed? See pauls sticky on measuring fuel pressure if you have no gauge.
        Volcano ABY coupe
        Ant
        • blackS2
          • Apr 2010
          • 455
          deleted
          [__]=oooo=[__]
          • JP
            • 1858
            If you drop compression there is less squish for igniting the fuel so you need to start burning it earlier and sometimes less of it too. Like Jamo said you need to remap by advancing ignition and trimming the fuel.
            UrS6 Stroker + HTA3586 =
            • blackS2
              • Apr 2010
              • 455
              deleted
              [__]=oooo=[__]
              • diesel des
                • 3896
                Sounds like a boost leak. Test with compressor. And a remap would be good, but it sounds like a leaky pipe ..
                • blackS2
                  • Apr 2010
                  • 455
                  deleted
                  [__]=oooo=[__]
                    I am surprised that is *SO* much richer purely because of lower compression - especially as you would expect closed loop lambda operation to adapt accordingly - of course that has its limitations, but I am wondering if fuel pressure is on the high side combined with an air leak... then combine that maybe with a marginal MAF and/or aging lambda probe... the combination of these things might be skewing it out of limits.
                    It is worth checking that something else hasnt been disturbed when the head was refitted.
                    Also worth checking air temp and water temp sensors are in spec...
                    Do you have VAGCOM there ?
                    • blackS2
                      • Apr 2010
                      • 455
                      deleted
                      [__]=oooo=[__]
                        yes I know that closed loop operation stops after a certain point... its not a pure rpm threshold on motronic though - are you on motronic or aftermarket ECU ?
                        • blackS2
                          • Apr 2010
                          • 455
                          deleted
                          [__]=oooo=[__]
                          • diesel des
                            • 3896
                            Try another maf. If the car is making 400 plus HP then the stock maf seems to drift in calibration before it dies. Mine did this a few times. I'm guessing your not stock power with low compression and moved maf...
                            • blackS2
                              • Apr 2010
                              • 455
                              deleted
                              [__]=oooo=[__]
