Bit of a long shot but perhaps the N75 is playing up in some way, can you try another without having to buy a new one?
Boost Issues
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
Also check the pipe from the N75 too the wastegate,. another thing, did you disturbe the N75 whilst fitting your RS2 air-box? If so is it fited the right way round?
I have a good spare N75 you could borrow for postage costs.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
This week I was working on a car with a failed N75... it was leaking internally so that air was bleeding from compressor port to BOTH other ports. That and another air leak made it run kinda ugly. It was a potentially dangerous fault too as the WG wouldnt open properly, but limiters in the ECU stopped it from self destruction.
Good way to test it is with ECU in output test mode when it is turning N75 on & off... while blowing air into the compressor port of WGFV - you can verify that the air path switches between the other two ports in response to on/off signal. Of course this is just a low speed test of N75 - it doesnt verify that it can follow the higher speed duty cycle (on/off) during normal operation.Paul Nugent
Thanks for the offer - I may take you up on that...
Where is it and what does the N75 look like... So I can check it out 1st...Comment
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)Comment
i know you said you can get boost for 1 second,but have you thought about knock sensors?
ive had this happen tome before
Not sure if Matt changed it yesterday... Will have to ask him..
Would this affect the boost??Comment
How does that relate to the fact that the diaphragm maybe torn?
You don't have to touch anything for it to tear.
Unbolt the cap and check the diaphragm, if it's torn, you will get overboost.Comment
I have no idea - as I'm not a mechanic - but thanks for the tip...
Are these units not pressurised in some way??
Does it damage them by opening it up???Comment
No!
Nothing will happen
Just carefull unbolt the screws around the wastegate cap, then hold the cap down, else it might pop off, make sure not to drop anything, the spring has stoppers on the top and bottom.
The diaphragm is the thing separating the upper and lower chamber.
Get your car tested for boost leaks as well, or rather vacuum leaks - pressure test from the MAF...Comment
