Boost Issues
  • K Simmonds
    • Dec 2007
    • 7627
    Bit of a long shot but perhaps the N75 is playing up in some way, can you try another without having to buy a new one?
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • K Simmonds
      • Dec 2007
      • 7627
      Also check the pipe from the N75 too the wastegate,. another thing, did you disturbe the N75 whilst fitting your RS2 air-box? If so is it fited the right way round?
      I have a good spare N75 you could borrow for postage costs.
      1994 MTM RS2.
      2000 B5 TQS.
        #33
        This week I was working on a car with a failed N75... it was leaking internally so that air was bleeding from compressor port to BOTH other ports. That and another air leak made it run kinda ugly. It was a potentially dangerous fault too as the WG wouldnt open properly, but limiters in the ECU stopped it from self destruction.
        Good way to test it is with ECU in output test mode when it is turning N75 on & off... while blowing air into the compressor port of WGFV - you can verify that the air path switches between the other two ports in response to on/off signal. Of course this is just a low speed test of N75 - it doesnt verify that it can follow the higher speed duty cycle (on/off) during normal operation.
        • Le S2 Audi
          • Jul 2009
          • 3805
          #34
          Thanks for the offer - I may take you up on that...
          Where is it and what does the N75 look like... So I can check it out 1st...
          New S2 - S8 & RS2 -RS6 Keyrings
          • Jas11n
            • 5067
            Three way solenoid valve located down behind drivers headlamp Ken.
            2001 Avus Silver B5 RS4.
            1995 S2 Coupe - sold (sniff)
            • AndyP
              • 6049
              HTH
              • andyg plym
                • Nov 2006
                • 4646
                i know you said you can get boost for 1 second,but have you thought about knock sensors?
                ive had this happen tome before
                • Le S2 Audi
                  • Jul 2009
                  • 3805
                  #38
                  Wouldn't that show on Vag Com thoo??
                  • dobbin
                    • Jan 2011
                    • 164
                    when was the last time you changed the fuel filter, because you did run it out of fuel
                    and thats never a good thing , see the recent thread on fuel pump delivery and try this
                    test . your car now needs more fuel than it did when std
                    • Le S2 Audi
                      • Jul 2009
                      • 3805
                      #40
                      Not sure if Matt changed it yesterday... Will have to ask him..
                      Would this affect the boost??
                      • Le S2 Audi
                        • Jul 2009
                        • 3805
                        #41
                        Originally posted by AndyP
                        HTH
                        Thanks Kit & Andy..
                        Will check that as it's just where the air box fits and maybe I knocked it..
                        • prj
                          • Mar 2010
                          • 6308
                          They have never been touched car was/is stock other than Homfries & RS2 MAF & Box..
                          How does that relate to the fact that the diaphragm maybe torn?
                          You don't have to touch anything for it to tear.
                          Unbolt the cap and check the diaphragm, if it's torn, you will get overboost.
                          • Le S2 Audi
                            • Jul 2009
                            • 3805
                            #43
                            I have no idea - as I'm not a mechanic - but thanks for the tip...
                            Are these units not pressurised in some way??
                            Does it damage them by opening it up???
                            • prj
                              • Mar 2010
                              • 6308
                              No!
                              Nothing will happen
                              Just carefull unbolt the screws around the wastegate cap, then hold the cap down, else it might pop off, make sure not to drop anything, the spring has stoppers on the top and bottom.
                              The diaphragm is the thing separating the upper and lower chamber.
                              Get your car tested for boost leaks as well, or rather vacuum leaks - pressure test from the MAF...
