V6 misfire
  • 220bhp
    • 2578
    • Home: United Kingdom
    V6 misfire
    My wifes 2.6 cabie has started to have what apears to be a single cylinder missfire,at first it was intermitent,I took it for a thrash on saturday and could not find a problem it ran fine.
    On sunday it had developed into a single cylinder missfire and at times it was very down on power. Plugs and air filter where fitted about A 1000ML ago along with the cats and the lamda. Any ideas would be much appreciated so I get some piece,at the moment all I am getting is mone,mone, mone,as you can imagine.
  • djh
    • Jun 2011
    • 1622
    if its gone to misfiring all the time now could be the POS packing up.
    • 220bhp
      • 2578
      THANKS
      • fzr phil
        • Sep 2006
        • 153
        could just be a dodgy lead, genuine replacement set is expensive but pattern ones exist. 2.6 and 2.8 is the same. i had the same issue with my mine, and it sorted it.
        phil
        (don't think there is a pos on that engine)
        95' 2.8E Coupe quattro pearl blue
        97' A3 1.8T Sport Auto Silver
        95' Yamaha FZR600R
        • spink
          • 4382
          its bolted to the bulkhead behind the throttle body
          • 220bhp
            • 2578
            Since the last post I have done the following.
            NEW LEADS
            COIL PACK
            POS
            DIFFERENT INJECTORS
            CLEARED CODES.
            NEW SPARK PLUGS
            The car ran better for a while but now it is doing it again. Plus when you start the car from cold it stalls a few times then it will run ok.
            I have tried to have the codes read,but with no success,the garage said there was no power to the connector in the fusebox,so they couldnt pull the codes.
            I have no idea where to look next, so any addvise would be appreciated.
            • andy10v
              • 5996
              If it is a single cylinder missfire and it does it at idle what can you isolate which cylinder it is? Eg unplug each plug in turn until one makes no difference?
              Sold ABY-stock
              • siV6Qcoupe
                • 41
                Do you know if the misfire happens to a specific cylinder or is the misfire random - happens to any cylinder? If it is random then possibly you are looking at a vacuum leak. You may need to take the black plastic plenum chamber off the throttle and take a look at the rubber seal, there is a trick where you can insert a piece of flat telephone cord under the seal to pad it out to create a better seal against the plenum. A failing fuel pump may also cause random misfiring when the engine is under load.
                If a specific cylinder is misfiring and plug, lead, injector and coil have all been replaced then a wiring check should be made at the injector plug and the coil pack plug also consider a compression check to determine if the cylinder is holding pressure.
                30v 80 Cabriolet - FOR SALE!
                • 220bhp
                  • 2578
                  Its a random misfire,I will check the vacume pipes,many thanks
                  • 220bhp
                    • 2578
                    At last the car is running right. It was the fuel filter,I looked at this and decided not to change it as it looked new and was tied down with a couple of cable ties,and like a prat I came to the conclussion it had been replaced.
                    Moral of the story trust nothing
                    • Alan King
                      • Apr 2020
                      • 4
                      Hi, just came across this post. I've been having the same problem. Was it sorted after the fuel filter? I've changed mine and it's still happening!
                      • Lago Blue
                        • Jul 2009
                        • 843
                        Hi Sir,
                        One can send the original poster a message that he's more likely to see by simply writing the "@" symbol directly in front of his screen name and then clicking on the little dialog box that appears, it then auto-morphs into this: 220bhp and perhaps he'll respond.
                        • Alan King
                          • Apr 2020
                          • 4
                          220 bhp hi, how is your car running? I'm having the same problem. Ive changed all of the same parts apart from the pos, (not sure what that is!). And still randomly dropping the middle coil in the pack. It's absolutely killing me!
                            The POS is the power output stage which drives the coilpacks.
                            • Lago Blue
                              • Jul 2009
                              • 843
                              If you still looking for the POS, (a great item for your on-board spares kit) it is bolted to the firewall approx. behind your throttle-body. If you can't find one at the wreckers cheap, before you spring for a new one, you may want to confirm that simply the wiring (conveniently under the intake manifold) between the POS and the coil-pack has not had its' insulation abraded and / or oil-soaked degraded to the point it's function is intermittent.
