With the WGFV disconnected the max boost I can get is .6 bar. With the bolt wound out the max is .4 bar. With the output from the WGFV plugged, the boost rushes off the scale ( mine reads to 1.5 bar ). I therefore assume that there are no boost leaks. I have the Samcos fitted + every last hose replaced. With all reconnected at standard setting, I think that the ECU is not allowing full boost. I can only get 1.0 bar up to about 4500 RPM and am toying with fitting a stronger WG spring and by passing the WGFV. Anyone else tried this? I know all about the failsafe built into the existing control.
Cheers James.
Cheers James.
