I had a few hours to kill last night and started a rather depressing spreadsheet to estimate the costs of building a monster I5 turbo engine. The exotic items on the list were a GT30R turbo, custom manifolds, intercooler, pistons, rods and a MOTEC ECU conversion for good measure (to remove the MAF and get an expensive but elegant programming environment).
The total came to a shade under £10,000 including VAT.
Now OK - I guesstimated some worst case costs which you might reduce by sourcing one or two re-usable engines, but the custom bits and all the obligatory new bolts, gaskets, seals and so on really mount up along with machining costs along the way.
That's just an engine build - never mind big brakes, a roll cage, coilover suspension, special clutch and transmission.
National Lottery anyone ?
Paul
Paul
