Cam Belt too big???
This is a sticky topic.
  • quicktrick
    • Feb 2011
    • 9
    • Country: South Africa
    Cam Belt too big???
    Hi, my mechanic is having a problem getting the correct timming belt. On the box of the new belt on the box it says Audi S2 1990-1995. This belt has 147 teeth and according to im should have 146 teeth. so it is too big. Any suggestions or information??
  • mcandmar
    • Apr 2004
    • 5118
    AFAIK S2 belt is 151 teeth. What engine is it?
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Ross
      • Aug 2005
      • 3399
      From previous research:
      The 3B (90-91) has 147 teeth, ABY (92-96) has 151 teeth. RS2 has 150 teeth.
        This topic came up last week on my home forum, quattroworld. I talked to my friend Kate and searched this forum for answers. This is what I came up with:
        "The OE timing belt for the the 3B, AAN and ABY is 054109119H, with 151 teeth. According the the S2 forum, the ADU timing belt has 3 fewer teeth (i.e. it is shorter), i.e. 148 teeth. (For reference, the The 7A timing belt has 147 teeth). ADU water pump has 26 teeth. The AAN and ABY water pump has 29 teeth (just counted the one I took out last year). This implies the number of teeth on the TB relates directly to the number teeth on the water pump."
        Hope that helps.
          Thanks Ross, you made me re-check the 3B belt. According to my friend Kate (whom I am sure told me something else last week), the timing belt for the NM, 7A and 3B is 054109119G "toothed belt" "147 Z." (147 teeth). The ABY does have the 054109119H *EDIT: H not G!!* 151 tooth timing belt.
          • quicktrick
            • Feb 2011
            • 9
            Thx sure this will help
            • AndyP
              • 6049
              Correct, I had all 3 when I was looking for a belt for the stroker
                Thanks for posting that photo. My friend Kate claims she doesn't know how many teeth on a 034109119C RS2 timing belt (I thought 148 based on 26 teeth on the RS2 water pump (vs 29 on the AAN/ABY)). But that photo clearly shows 150. I am stealing that photo to share. Hope you don't mind (I will give you credit).
                Dave F.
                • AndyP
                  • 6049
                  Dave F.
                  Help yourself, I thought it may come in useful at some point
                    Thanks very much. Here it is:
                      Ditto!
                      • Fat Audi 80
                        • 10547
                        Should we stick this the information seems particularly important, or is this captured elsewhere?
                        The Perfectionist
                        • quicktrick
                          • Feb 2011
                          • 9
                          So guys, The 147 teeth belt is supposed to be the right one for my 3B, but somehow it should be a 146. I even went there myself and counted the old belt three times 146. Now I can not find such a belt. Somehow along the line something has changed. Me and 3 mechanics is now out of suggestions.
                          • chezz
                            • Apr 2007
                            • 440
                            This has been mentioned in a previous thread on here and it wont make any difference... excess teeth after the cam timing gear should not be a problem as the cam/pump tensioner should be able to adjust enough with one extra tooths length. The timing will not be thrown out by one extra tooth as the main factor is the distance from crank pulley to the camshaft pulley - this will not be affected once it is tensioned.
                            Put it on and do not start the engine rotate the engine manually several times and it will still line up with all the timing marks. Crucify me if I'm wrong boys!!!
                              I agree with Chezz for a different reason, the car is suppose to have a 147 teeth belt on it in the 1st place so why would you want to put 146 one back on that is clearly non audi or for your car?
