Cam Belt too big???
This is a sticky topic.
  • #16
    That idler pulley dont look right, NEVER seen a plastic one before so i bet its off something else / different size.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • #17
      Here is a pic of my 3B set up, this is a genuine idler from Audi
      Looks to be a similar size to the water pump sproket, your's looks smaller? I'll have a look around in a bit and see if I have an old one I can measure.
      • #18
        THx
        • #19
          That must be it then the idler is wrong part because the 147 teeth belt can not tension enough. Now well get somewhere! Thx again for the information as I stay in a small town where there ain't an Audi dealership that I can get information from. As I have send the S2 for an oil leak repair and it spiraled out to this headache for a week now trying to find info. Thanks again.
          • #20
            Cam belt idler on a 3B is 75mm dia.
            • #21
              Thank you once again for the info. The S2 is fixed and going like a S2 should. Dont know how and why it had the wrong Idler and belt, but all is back to original and running.
              • #22
                this thread give me all answers what I want to know..
                my timing belt on 3B have 147 teeth , but it seems that 1 is too much.. so I taught that belt must have 146.. I fix that with adjustible cam pulley
                but now I know where could be a problem.. IDLER.. hmm must go and take a look..
                will post you later .. thanks guys !
                • #23
                  well ETKA said the idler must be 74mm and belt 147 teeth, same as 3b,nm,7a,1b,mc,
                  i messured today my idler and i have 74mm , where is than problem with my engine?
                  • #24
                    Just to confirm, my original belt has 152 teeth the cambelt kit i bought the belt seems to be shorter it only has 146 or 147 teeth will this be ok to use?
                    • #25
                      Nope, sounds like your kit is for a 7A/3B.
                      As for QuickTricks issue, i recently discovered the plastic idler pulley is actually for the 2.6/2.8 V6 engine.
                      • #26
                        mine sounds like that heres a pic
                        • #27
                          I don't think that kit is for an S2, you have too many idler pulleys and the tensioner looks wrong.
                          • #28
                            Ok cheers Andy,
                            Does anyone know what this kit is off
                            • #29
                              Thats all wrong, i would lay money its a 2.8 v6 kit.
                              • #30
                                Cheers mate
