Sump buffles
  • Billman
    • 4129
    I have done it today and it drops :-)
    Go Holset or Go RS4
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      If it always drops, then how detrimental is it for the engine? As all 5cyl engines would have this issue
      sent using Android
      • Billman
        • 4129
        Maybe just an extra safety
        Go Holset or Go RS4
        • Thuppu
          • 4115
          If you use full boost and max rpm's on a 400-600hp engine and your oilpressure drops to zero for a second it's propably "bye bye then".
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #20
            Never seen that happen, and if that was the case it doesn't have to be an 400hp engine. It can happen in any engine
            sent using Android
            • Thuppu
              • 4115
              Yes, of course. Oil pressure drop is not good at any time. But on a high power engine at full load the bearing are gone stright away. Havn't experienced it my self but it's what I have heard.
              • Thuppu
                • 4115
                Here is RWD19T's sump mod:
                • Billman
                  • 4129
                  #23
                  I have searched a bit about those buffle and also found these designs:
                  with hinges from
                  The World's Largest Community of RX-7 Owners and Enthusiasts
                  I maybe fabricate a buffle system on my spare pan for the next time the pan is out.
                  Go Holset or Go RS4
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #24
                    pictures cannot be seen Bill
                    you need to download them and save them in the forum, not as links
                    • Billman
                      • 4129
                      #25
                      done
                      Go Holset or Go RS4
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #26
                        nice work there.
                        • Thuppu
                          • 4115
                          Those rubber flaps are hard to find. I'll tried to find some... Cosworth made them, but seems they don't sell them separate. BMW M3(e30) has them as stock in the oil pan, part number 11131309428 item 8 in the pic http://www.realoem.com/bmw/showparts...72&hg=11&fg=10 but they are quite expensive, 14 euro each and you need maybe 6-8 of them. Thats why I did steelflaps at 0 costs.
                          • quattro84
                            • Mar 2006
                            • 947
                            I've seen those flaps in a ~5 year old WRC car and they don't seal that well. Because of the temperature of the oil it doesn't stay completely flat over time.
                            • Billman
                              • 4129
                              #29
                              then i am going for the metal ones. I think the mos important position is in the oil pan extension as this provides a bigger space.
                              Go Holset or Go RS4
                              • JariP
                                • 192
                                If you have an oil pan in your hands, put couple litres of water in it and tilt it side to side and front to back, it gives you some ideas what's happening in there while driving. 45° tilting equals to 1G acceleration, I think. Stock I5 oil pans are not so bad, running out of oil in general from the pan could be bigger problem than controlling the oils movement in there.
