Introductions, 20vt BTDT
  • RSCoupe
    • Dec 2003
    • 120
    Originally posted by Greg_S
    Des, have you any details on the RS tuning manifold?
    Please post some pictures. I'm in the US group buy , but we haven't received the shipment yet.
    Mark Siggelkow
    '90 CQ 20vT - NASA GTS-5 (R.I.P.)
    '90 CQ-R - NASA GTS-4/5
    '00 A4 1.8TQMS (Wife's Daily Driver)
    '12 TT-RS (Wife's new DD, on order for May European delivery)
    '62 Porsche 356B (another race car)
    '03 Kawasaki Z1000 (toy)
    • diesel des
      • 3896
      #32
      I have some picks at home, but also a crap dial up. Will get some up here when i get a chance. (In the middle of changeing 2 engines for friends at minute )
      • diesel des
        • 3896
        #33
        i did send some pics to Hap last week. He should have some. Thanks,des.
        • JSHADZI
          • Oct 2004
          • 66
          #34
          Originally posted by diesel des
          Hi. I am interested in seeing some power graphs of cars with the GT30R turbo. I have one, a Aby, and a urq, but none are screwed togeter yet. Just wondering what i could expect. Thanks!
          Hello, next week I'll be dynon tuning an 034 equipped, 2.6l flowed 10v with a GT30R on it, I'll be sure to post results. I estimate about 400crank HP at 20psi boost, with a very healthy TQ curve. The overall power output doesn't seem to be increased much with the stroker, but the power band has shifted down lower in the RPM band with very useable power from 3k to 6krpm.
          Javad Shadzi
          www.034motorsport.com
          www.80tq.com
          • Josh-stateside
            • 741
            Hi javad
            I read something interesting last night.
            Corky bell's book states: "When an engine is equipped with a speed density type of efi system where no air flow meter is utilize.. the length of the intake tract can extend into the next country with no negative results insofar as throttle response is concerned."
            Some thing like dalback's, aan, mtm's intake manifolds increase throttle respose because it's a shorter distance of air flow. They also reduce the intake manifolds heat to some degree.
            But for your application with the huge intercooler that you have would a aan really do anything for you? Or is it just overkill? We all love to go over the top but I am just curious what benifits would you gain with this setup? Besides heat reduction?
            Constantly learning here.
            THanks
            Josh
            • JSHADZI
              • Oct 2004
              • 66
              #36
              Originally posted by Josh-stateside
              Hi javad
              THanks
              Josh
              Hey Josh, thanks for the dialogue, I'm not very concerned with increasing throttle response (since its already quite razor sharp for a heavily boosted 4v motor) or boost response (its seems to have come up in this thread, but if you look at my original post, you can see my original intent). My concern is increasing flow through the induction system, as I have a suspicion that the 3B IM I'm currently running could be limiting flow into the motor.
              From a glance, the AAN appears to have a much larger plenum volume and free-er flowing design compared with the 3B. I'm really interested to hear if anyone has "scientifically" upgraded from the 3B to the AAN and measured the result in power increase, or for that matter, what the highest output 20vt motor is out there running this 3B IM. Most of the really high output motors I've seen run either the AAN or custom IM's.
              What I'm considering doing is pulling off the 3B, removing all the bolt access supports and porting/flowing the plenum w/o any other changes, and going back to the dyno to see if/what improvement there is. FWIW, the inside of a 3B IM is horrendously crammed with these supports that would seem to wreck havoc on flow - but its tough to say how limiting they really are.
              Thanks,
              Javad Shadzi
              www.80tq.com
              • Doug_RS2
                • 3847
                #37
                The AAN inlet is crammed full of bolt acess runners as well - I cut them out of my AAN manifoldc
                • JSHADZI
                  • Oct 2004
                  • 66
                  #38
                  Understood, but it appears that the overall volume of the AAN is considerably bigger.
                  Have you been able to measure the improvement in power over the modification you make? Very interested in any discrete information.
                  Javad Shadzi
                  www.80tq.com
                  • audiman
                    • 4827
                    Im not sure, but i think i must have one of the most powerfull cars still using the stock 3B manifold. Im planning on doing a RR day soon, before i change the manifold. I could re do this RR session, but it maybe in a few months time
                    Tom C - www.rcmr.co.uk
                    Audi UR Quattro
                    Audi 100 C3 2.0 5 cyl 115ps
                    Audi B5 RS4 645ps 911nm
                    • Josh-stateside
                      • 741
                      Why not just fill up both intake manifolds with water and see what's the difference?
                      Also what about extrude and honed? Do you consider it too expensive?
                      Josh
                      • audiman
                        • 4827
                        What do you mean by that Josh?
                        Audi UR Quattro
                        • auditude
                          • 407
                          He's referring to "extrude honing" a proprietary process by a firm here in the U.S. that forces an abrasive media though ports to smooth them and change their shape. It's very expensive, like $500+ for a manifold I think. I don't think the gains would be as great as eliminating the service tubes and relocating the throttle body to the front.
                          Extrude Hone offers Metal Part Finishing with machines, Contract Shop Services, Abrasive Flow Machining, Electrochemical Machining and Thermal Deburring.
                          Kenneth
                          1990 Coupe quattro
                          1991 200q20v x 2
                          1985 4ksq 20vt project
                          1986 Coupe GT 10vt project
                          2006 Honda Ridgeline
                          1998 Honda VFR800FI
                          • audiman
                            • 4827
                            Thank you for the explaining! Although that link doesnt work for me.
                            Audi UR Quattro
                            • auditude
                              • 407
                              No problem! It didn't work for me when I posted it either, it's very slow but I got it to work now. If you're curious, check it out. It's pretty cool, just too expensive. I would love to do it to my Wagner intake, as it looks very rough inside. But I understand that doesn't matter all that much, at least not $500 worth for the perhaps insignificant gains.
                              Kenneth
                              1990 Coupe quattro
                              1991 200q20v x 2
                              1998 Honda VFR800FI
                              • JSHADZI
                                • Oct 2004
                                • 66
                                #45
                                http://www.extrudehone.com/
                                Yes, agreed, gains are minimal IME and VERY expensive.
                                Javad Shadzi
                                www.80tq.com
