The RS2 started behaving a little 'off' yesterday... feeling a bit sluggish, and only 1.1bar of boost (I thought it was on stock spring but obviously not!). I took it out for a drive today, problem persisted, then the coolant warning light came on and does every time you start it now. I pulled the MFTS plug and confirmed that was the issue.
The plug seemed damp - must be a very slight leak from the MFTS... pulled back the rubber boot to find it was half full of coolant and the wire joins are very corroded. To the point where one of the connections has completely disintegrated and the wire (with half a spade) was hanging out. Explains the warning light...
I think the ideal would be to cut the plug off, strip back the wires and connect a new plug. If access is a problem, connecting 4 new wires and crimping them onto the loom may be the way to go. Question is... where can I get a new plug without buying a donor loom?
For a temp fix I'm thinking attach 4 spades, slide onto the MFTS and bind it up with insulation tape until I can fix it properly... any reason this would be a bad idea
