Many Internet shops have the same sensor for all these part numbers.
AEL crankshaft positioning sensor
Can someone please explain me something in matter how Motronic or VEMS triggers:
The ECU sees the crankshaft pin through the G4 sensor and tha hall windows so that it knows when the 1 piston is on top. After that though the G28 sensor and the 135 tooth it knows/calculates the engine RPM and crankshaft angle correct??
Till now I just concentrated to the flywheel pin but maybe the problem is on the other sensor that reds the 135 tooth.Go Holset or Go RS4Comment
G4 crank position and G28 engine speed sender info
You have it pretty much correct. Have a read on this post and see if it makes sense relative to what you said above:Can someone please explain me something in matter how Motronic or VEMS triggers: The ECU sees the crankshaft pin through the G4 sensor and tha hall windows so that it knows when the 1 piston is on top. After that though the G28 sensor and the 135 tooth it knows/calculates the engine RPM and crankshaft angle correct?? Till now I just concentrated to the flywheel pin but maybe the problem is on the other sensor that reds the 135 tooth.
