I have a couple of strange issues appear on my 3B.
First off the battery will go flat if left for a few days yet if I switch off, disconnect battery and introduce ammeter between terminal and cable and then lock the car there is no more than 3 or 4 milliamps flowing, presumably for the clock.
A possibly related symptom is that when switching on the ignition in the morning after zeroing the hour meter the night before, the hour meter will show 8 or 10 hours, ie the car thinks I've been driving all night, so something is definitely staying powered up.
Lastly (at the moment lol) The trip computer has stopped showing the average readouts, they both show 0.0 and the MPG reads 200 on the throttle and -- -- -- off the throttle.
I have been looking at the circuit diagram but not sure which signal I should be trying to trace and where to look for the A23, 27, 42, 45 connections might be found. Also if there's an obvious connector which may have come unplugged!
Any help here would be greatly appreciated!
Circuit diag below
Circuit diag below
from the symptoms above it would appear that the "consumption" signal is not actually getting seen by the cluster. The car knows it is moving but thinks it is using no fuel hence immediately reading 200mpg. As PRJ suggested I'm going to try and look at the signal on another car to see what it looks like.
