New Turbo, 3" full Turbo Back Exhaust system. Oil Feed -4AN
I have the Standard oil drain going to the top of the appendage on side of the sump pan, can this cause a Turbo to pass oil into the exhaust due to back pressure and lack of it from the exhaust. This set-up correct oil level is higher than connection on the pan with the oil quite far up the return pipe from the Turbo.
I'm thinking Possible + pressure on oil return vs no + back pressure from exhaust system to the Turbo causes a leak ????
Would i be better fitting the return that mates on to the side of the block ?
Any experience with this problem or thoughts ?
