HX35 in 48/81 on the left and 56/82 billet compressor on the right.
Holset HX35 - Flow Chart
I like the look of that! I'm thinking it would work really well on the stroker, dam you guys are bad for my bank balance
1976 RD250E / 350LC cafe racerComment
you mean HX35?
If yes the nthe 12ccm should be a nice compromise between spool and restriction.
I and Nervas used the K26-6 housing with good results to the HX40 turbo. Since the HX35 turbine is smaller then the K26-8 would be a nice pair if you want to run a K26 manifold.Go Holset or Go RS4Comment
