Holset HX35 - Flow Chart
  • Billman
    • 4129
    #76
    On the hybrid hx35/40 and the 2 super 40 I have the compressor side is the same. All have the 7 blade 60/85 compressor.
    Go Holset or Go RS4
    • ian4455
      • Nov 2010
      • 787
      What diameter do the housings measure ?
      • Billman
        • 4129
        #78
        On the outside? I had to use a spacer approx 10mm (can't quite remember) for it to fit with the k26 housing on a stock rs2 manifold.
        Go Holset or Go RS4
        • ian4455
          • Nov 2010
          • 787
          8 blade, 54/81 on compressor wheel. diameter of housing is approx 180mm. Hotside is kkk with 60/70 turbine. 8 cm3 volute.
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            #80
            That looks good, but I'm wondering how restrictive the turning housing might be.
            sent using Android
            • ian4455
              • Nov 2010
              • 787
              Just wondering if any turbo experts on the forum could advise.
              • Billman
                • 4129
                #82
                Very nice. It will be enough for 450hp maybe a bit more. Where did you get the housing from?
                Go Holset or Go RS4
                • ian4455
                  • Nov 2010
                  • 787
                  Housing is HX35 the smaller option available.
                  • Billman
                    • 4129
                    #84
                    I mean the K26-8 turbine housing.
                    Go Holset or Go RS4
                    • ian4455
                      • Nov 2010
                      • 787
                      Sorry should have said K26-6 housing.
                      • Billman
                        • 4129
                        #86
                        aha ok. Still calculate with 450+ with this combo.
                        Go Holset or Go RS4
                        • ian4455
                          • Nov 2010
                          • 787
                          What could a stock HX35 56/82 60/70 mated to a no 10cm3 hotside produce ?
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            #88
                            Ian, all anyone would tell you is speculation. I thought that a 0.70AR would be ok for a SuperHX40 in regards to spool and it turned out to be horrible for my taste (4600rpm for 1.8bar on 3d gear).
                            If i were to use a holset again and would like the midrange, i would go for the smallest hotside possible and not worry about the final hp figure if using the HX35 or HX40 in a hybrid form!
                            • ian4455
                              • Nov 2010
                              • 787
                              ok thanks, still a lot to learn so putting the feelers out for advice.
                              My car's going to be off the road shortly for further upgrades, so considering options even though i may not fully understand everything.
                              • Billman
                                • 4129
                                #90
                                probably spool a bit later than the K26 housing and will produce a bit more.
                                Go Holset or Go RS4
