oil leak!!!!!!!!!! help
  • filip.krticka
    • Sep 2008
    • 170
    • Home: Czech Republic
    I had the same problem 2 years ago... That was really easy to fix it.
    • GavS2
      • Nov 2010
      • 73
      I had this problem four weeks ago on my avant, i was driving down the motorway and noticed a blue trail of smoke behind me. Pulled over and there was a steady stream of oil pouring out from the lower engine cover. Turned out to be the oil pressure switch, the oil was coming out through the switch, between the metal nut and the plastic white switch, i also had no oil pressure issues on the gauge. I managed to remove the old one by just removing the radiator fan cowling and leaving the rad in place, easy fix but as all things on an S2, awkward. Goodluck
