oil leak!!!!!!!!!! help
  • vonbeck
    • 2455
    when i got home tonight and got out of the car i noticed a black speckled trail behind me on further inspection it seems to be coming from the white sensor in the pic below can anybody tell me what it is and has this happened to anybody else? its on the right hand side below the oil filler looks a real barsteward to get at
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    that is not a white sensor, that is the oil pressure sender and next to it is the dipstick. Oil could be coming from either these 2 at their bolts.
    • Dingo
      • Jan 2008
      • 229
      Thats your oil pressure switch and yes its in a bad place because of the plastic cowling right next to it, see pic.
      • driftin jo
        • Sep 2007
        • 2222
        The little one is the oil pressure switch, one above is oil pressure sender.
        Never seen either of them leak but I suppose there is a first time for everything.
        • A80Avant
          • Sep 2005
          • 10873
          • Country: Greece
          mine may also be leaking atm, and ill have more photos on saturday once the radiator is out of the way....
          • vonbeck
            • 2455
            god i love this forum 9 minutes from posting and i get a reply, i dont think its coming from the dipstick its a bad leak its pouring out but no drop on the oil pressure gauge is it wise to get a new one?
            • vonbeck
              • 2455
              is this the correct part number for aby?
              056919081E
              and is it a dealer only or gsf etc ta
              and sender g10
              034919561 ta very mucho
              i believe its a bendy spanner job anybody know the size it is?
                056919081E and is it a dealer only or gsf etc ta
                and sender g10 034919561 ta very mucho. i believe its a bendy spanner job anybody know the size it is?
                F1 oil pressure switch. Very common failure point. Will p*ss out oil in a stream and empty the sump in short order.
                056919081E is the correct 1.8 bar switch, very common across the Audi and VW line (but not the UrS6 which used a 1.4 bar switch). Dealer or aftermarket but Dealer is probably safer. More info here:
                • vonbeck
                  • 2455
                  bloody brill thanks guys
                  • mcandmar
                    • Apr 2004
                    • 5118
                    I had to change mine a few weeks back for the same issue. Ended up having to pull the radiator out to get at it, good luck
                    91CQ20v - Gone to a new home
                    93UR-S4 - The Magic Carpet
                    94S2Bus - The Emerald Express
                    • TDi90
                      • Nov 2009
                      • 272
                      Yep, i did mine and the rad and cowling had to come out.
                        Sometimes I think its quicker to just bite the bullet and take the rad out, I can do mine in 10 mins now (but I don't have AC or the plastic shrouds), you can be sure they're done up correctly too. Good opportunity to check and clean the MFTS connections too. And the small hoses circled in the post above
                        • vonbeck
                          • 2455
                          Probably take out the rad I suppose there is a sticky for it
                          • johne
                            • Apr 2007
                            • 1404
                            If you don't want to take the radiator out because you don't want to loose the coolant or you have A/C then you can remove the power steering hydraulic pump instead and get to the oil pressure switch that way.
                            Equally if you don't have A/C, you can remove the top radiator stay, loosen but not remove the bottom radiator mount, undo the side radiator mount where it attaches to the inner wing and you can tilt the top of the radiator forwards enough to reach the oil pressure switch without draining the coolant.
                            John
                            • vonbeck
                              • 2455
                              cant get the part till tuesday but will have a go at freeing up the rad as johne has described, if its not pi@@ing down tomorrow cheers
