Hey all,
Have fitted my gauges and sensors, but think i have problems.... (1990 Audi 90 2.3E NG engine)
Can someone tell me what the oil temp reading should be when the car is up to temperature under normal driving?? Mine is sitting between 60 and the first bar after it.....
The oil pressure gauge is reading as it should, just a touch under 5bar when started cold, and settles down to 2bar once warm........
BUT.... Once the car reaches 3000rpm the oil warning on the auto check is coming on.....
When i swap poles on the sensor, the gauge doesn't work ie bounces right up to maximum reading, but i get no autocheck warning..... Is the sensor faulty? Are both sensors faulty??
TIA
Dan.
TIA
Dan.
