help with blinker
  • ian4455
    • Nov 2010
    • 787
    help with blinker
    Where do you plug in a blink code test on a 3b, i've a unit two yellow wires and a red/black with a led and push button.
    Need to know where this plugs in on a 3b
    Do i turn ignition on and press the button on the blinker then count the number of times the light flashes ?
    3B 200 20VT diagnostic
    This might not work for you with an S2 3B but here is some 200 20VT 3B info (note - see follow-up post below for location of S2/RS2 diagnostic plugs):
    http://www.sjmautotechnik.com/troubl...html#20v_check and
      Location of S2 and RS2 OBD1 diagnostic plugs.
      Location of the S2 and RS2 diagnostic plugs is at the left side of the under bonnet/hood fuse box, as shown here:
        www.s2central.net is your friend!
          If the plugs are not in the fuse box they will be probably be hanging down below it!
