I've just taken the plunge and have bought a new 19 Row Mocal Oil Cooler + JIC fittings.
It's a 235mm wide matrix, 335 overall width including brackets.
147mm high + fittings ~ 75mm H and 90mm width, in whatever direction.
I will be fitting this in the space vacated by the Aux Rad, RIP.
I believe this is a fairly common modification, particularly on the continent. Along the same lines, I thought to ask if anyone might have a drawing I could use for a custom bracket to mount the cooler on the RS2 cross member/slam panel. Hoping some of our continental cousins might be able to help?
If not I will make one up and have some stainless steel brackets fabricated to make it work. Anyone else interested in a set of brackets? I reckon there must be some forum members without Aux Rad's who would like some decent oil cooling...
Thanks for any input!
so safer in my view...
