just got the rally car back from jaspeed ,had it on the rollers max bhp 255 , max torque 377@ wheels with 34mm restricted fitted and on pump fuel, so quite happy [always want more] trying to work out how much power at engine ,am i wright in thinking we loose 30% on 4wd cars and 20% for 2wd, any one know correct figure ?
how much bhp loss on 4wd rolling road ?
why you would do this?
Drive train loss is different per car and different dyno's have different ways of calculating it and is biggest bone of contention on dyno results.
If they didn't calculate it then I would say realistically a 20% loss is a good start.
The defacto value used is 25% but I do think that is highComment
You need to go to a engine dyno then to a 4 wheel dyno then you will have the loss. Its the only way to get a real world %
But this is pretty motor sport budget stuffChefComment
034 has done back to back testing on engine dyno and chassis dyno.... and have come up with ~18-22% drivetrain loss.
