how much bhp loss on 4wd rolling road ?
  • A1quattro
    • Jul 2006
    • 789
    just got the rally car back from jaspeed ,had it on the rollers max bhp 255 , max torque 377@ wheels with 34mm restricted fitted and on pump fuel, so quite happy [always want more] trying to work out how much power at engine ,am i wright in thinking we loose 30% on 4wd cars and 20% for 2wd, any one know correct figure ?
  • A80Avant
    • 10873
    • Country: Greece
    too much for 30%
    some say 25% for 4wd cars and i think that is also overrated
    • A1quattro
      • Jul 2006
      • 789
      if i add 20% that gives me 306bhp and 452 torque
      • Val
        • Apr 2008
        • 630
        • Country: Latvia
        so, nobody has ever taken off propshaft and tested car on rollers with center diff locked?
        5vtq gte
          why you would do this?
          Drive train loss is different per car and different dyno's have different ways of calculating it and is biggest bone of contention on dyno results.
          If they didn't calculate it then I would say realistically a 20% loss is a good start.
          The defacto value used is 25% but I do think that is high
          • terrybullwon
            • Mar 2006
            • 8782
            You need to go to a engine dyno then to a 4 wheel dyno then you will have the loss. Its the only way to get a real world %
            But this is pretty motor sport budget stuff
            Chef
            • speeding-g60
              • Aug 2008
              • 1186
              034 has done back to back testing on engine dyno and chassis dyno.... and have come up with ~18-22% drivetrain loss.
                Mine was ~240 at the wheels and ~300 back calculated at the fly.
                • Avantus
                  • Sep 2007
                  • 941
                  • Country: Belgium
                  You can't really put it in %, but only in true numbers.
                  a 300hp vs a 600hp car with the same drivetrain won't have double the losses.
                  • A1quattro
                    • Jul 2006
                    • 789
                    The rally car was fitted with a standard 01e dsy box when on rollers 255@ wheels , will i gain any more bhp when the 01e dogbox is back in the car[curently having 4.375crw/p and plated lsd fitted]
