Possible Oil Leak
  • Bowlerwell
    • 1052
    Possible Oil Leak
    We changed the oil on the RS2 today, but when I took the undertray off the car I discovered what looks like an oil leak
    I did my best to trace where it comes from, and it looks like the PAS pump
    Question is, how can I tell from the drips on the underside of the sump cover if they are engine oil or PAS fluid?
    In any case, I assume the X-bolt on the PAS pump isn't supposed to have fluid/air bubbling round its edge...
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
    THis *could* help you (it comes from a AEC V8 vane pump listing but I know it works on the AAN tandem vane type pump (and therefore I presume ABY and ADU)).
      /\ Replace that o-ring. I also wrapped lots of PTFE tape around the threads on my plug, that helped a lot.
      • Al Wyn
        • Nov 2006
        • 3746
        Had to replace this on both my old laser S2 avant and black RS2 too John.
        S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
        • Bowlerwell
          • 1052
          Do you have the X tool Al, or did you make do with a large screwdriver?
          John Bowlerwell
          Electronic Engineer
          Present:
          Previous:
          • Al Wyn
            • Nov 2006
            • 3746
            Did you have to ask John?...big screwdriver
            • Bowlerwell
              • 1052
              Ok, to replace this plug, I need to remove the connection on top of the PAS pump.
              Do I need to do anything in preperation to take this off?
              or do I just need to pump the brake pedal until hard, then remove the pipe and catch the dribbles?
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
              • johne
                • Apr 2007
                • 1405
                No, just go ahead and undo it - assuming the engine isn't running
                John
                • andy10v
                  • 5996
                  You might need an impact screwdriver with a big bit, or a chisel to get the plug out.
                  I would clean up the oil/pump first and then try and see where the fresh oil comes from. The pump X plug is a common leak though.
                  Sold ABY-stock
                    Check and replace the O rings on the other 2 small brass plugs too, mine was leaking from both.
                    The big banjo bolt that goes in the top of the pump has a mesh screen in it, this needs to be cleaned, if it is clogged it can cause the big O ring to fail
                    • Bowlerwell
                      • 1052
                      Thanks Newsh, do you have part numbers for these o-rings, or dimensions?
                      John Bowlerwell
                      Electronic Engineer
                      Present:
                      Previous:
                        Any oil that has missed the filler hole will drip down that side of the engine Give it a smell to see what sort it is...
                        • Bowlerwell
                          • 1052
                          Ok, I have a problem.
                          There's a bracket holding the pipe over the top of the PAS pump in place... But i can't get a socket or spanner onto the bolt...
                          Can anyone give me advice on how to get the thing off?
                          John Bowlerwell
                          Electronic Engineer
                          Present:
                          Previous:
                            how come you can't get a spanner on it mate?
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              Photo might help someone advise.
                              1990 B3 2.0 80 quattro.
                              1992 C4 2.8 Avant quattro
                              1994 MTM RS2.
                              1998 B5 TDI quattro Sport.
                              2000 B5 TQS.
