Advice pls gents
I managed to shear one of the camshaft bearing cap retaining studs last night
I've had the head off to replace all the inlet valves (all bent after crankshaft pulley key failure), was in the middle of tightening down the bearing cap nuts to 15nm as per manual, just starting to think this doesn’t feel good when one went.
Has anyone had this problem before?, on inspection all 12 inlet studs look to be showing 2-3 threads extra vs exhaust side studs (which are untouched) and still haven’t 'locked' down, so studs must be stretching !
Also any ideas on where to get replacements?...or is it a Audi dealer job + how difficult are they to get out ?
James
.I've had the head off to replace all the inlet valves (all bent after crankshaft pulley key failure), was in the middle of tightening down the bearing cap nuts to 15nm as per manual, just starting to think this doesn’t feel good when one went.
James
