Hi all,
I have just cleaned my MAF in IPA in the hope it would give me better mpg/power...
N75 valve is disconnected, and there is some sort of chip switch i have bypassed i understand its some sort of superchips chip?
the problem im having is there is a stutter/hesitation 3rd gear, when belting it/joining the motorway.
If im giving it beans on local roads, its not noticeable, Initally i thought its the maf hose not on properly, Ive secured this to the point where if i tighten it anymore the jubilee clip will snap!
Im thinking, leaking diverter/dump valve maybe? (standard item at the moment)
or is this a symptom of the car knocking/pinging? i run it using BP optimum unleaded fuel.
Im sure this car has soo much more to give.. powerwise.
or could it be a lambda sensor issue, I have yet to VAGCOM it, got lead and VCDS just working all hours at work
any thoughts/ideas/suggestions would be much obliged.
Many Thanks in advance..
Im sure this car has soo much more to give.. powerwise.or could it be a lambda sensor issue, I have yet to VAGCOM it, got lead and VCDS just working all hours at work
Ive not long changed the coils
Basically, you pull off the hose at the maf and plug it with a cap with a tyre valve in it and blow in air from a compressor, this will show up any big leaks in the inlet tract and PCV system. To really test the IC and inlet hoses properly up to a bar or so you need to isolate the PCV by disconnecting and plugging the connection on the side of the maf hose (20mm plug) and the hose going to the boost tube.
