GT3076R vs GTX3071R
  • driftin jo
    • Sep 2007
    • 2222
    Well, you couldn't upgrade a GT3076 to a GTX3071 (without the comp housing) as the GTX3071comp wheel is smaller. GT3076- ind57mm exd71.4mm / GTX3071 -ind54.1mm exd71.4mm
    You could of course upgrade a GT3076 to a GTX3076 as the GTX3076 is ind58mm exd 76.2mm, a quick skim of the comp housing and bobs your uncle.
      Turbo dynamics don't do them they developed their own wheel instead
      • A80Avant
        • 10873
        • Country: Greece
        #33
        Problem is that in my setup, maybe a GTX3076 wont give too much as an advantage, esp. with the small hotside,as i wouldnt be able to hold too high boost up in the revrange. The 3071 on the other hand, might come in handy, esp. if keeping the same boost characteristics is able to push more air than my current setup.
        I think the HTA one which is 54.8/76.6mm is sort of in between the 3071-3076 and able to produce the in between power as well(according to FP). At a 600$ cost, its not that bad, trouble is the costs rise due to shipping and possible customs.
        damn...
          Owens in the uk do the hta wheel it's what should be on RWD19t turbo
          They will do it on a used turbo I have the emails etc
          • A80Avant
            • 10873
            • Country: Greece
            #35
            aha,
            how much do they charge for it?
            can you pm me any details please?
            thanks
              There is no set price as they evaluate your used turbo 1st
              • A80Avant
                • 10873
                • Country: Greece
                #37
                in what way? if it runs ok first to do the upgrade? or do they keep the previous wheel as exhange?
                • A80Avant
                  • 10873
                  • Country: Greece
                  #38
                  a friend of mine sent me a post from his 1.8T engined HTA 0.82AR 3076R turbo. I have calculated with the VDR 400-450whp, which is way more than what mine does on my current setup.
                  Have always wondered how the 4cyl engines can make so much power!! His 3d gear shows full boost by 4000rpm.
                    You have to ask them
                    if your turbo isn't deemed in fit condition they won't do it without you paying for the turbo repair during the upgrade
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #40
                      Ah. I see. Did they ever tell you the cost if the turbo is fine after their check?
                      sent using Android
                        You need to speak to them
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #42
                          I will email them.
                          sent using Android
                          • diesel des
                            • 3896
                            #43
                            Turbo dynamics WERE able to get these bits. My contact worked there. Was also able to get the "cant be done" bearings for a rebuild of a gtr Garrett. I wonder if the billet wheels they sell now are Garrett copies and Garrett pulled their plug...
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #44
                              official garrett distributor is owen apparently. TD is not mentioned.
                              • Bram
                                • Aug 2006
                                • 2582
                                This thread looks like a nice tea-get-together-party
