is the mpg on the on bord computer take the signal from the maf? because its playning once 40 litre per 100 km in the citry drive and once 0.0 and mostly 20 litre is it a reason for a dirty maf? ill be thanksfull for any information about that!!
Maf Information Needed.
No. But dirty MAF can foul tha ECU and misleads the display. Also bad MAF cable contacts can do the same sh...,,te. Take a deep breath and clean the MAF gently and at the same time take care of the contacts too. Fuel consumption should go down to some 11-12 in a warm land like yours. Depending on the air filter the MAF should be cleaned every now and then...Of course many other faults can cause your problem....Originally posted by kniniois the mpg on the on bord computer take the signal from the maf? because its playning once 40 litre per 100 km in the citry drive and once 0.0 and mostly 20 litre is it a reason for a dirty maf? ill be thanksfull for any information about that!!
Gabor
96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF -
Originally posted by horvathgNo. But dirty MAF can foul tha ECU and misleads the display. Also bad MAF cable contacts can do the same sh...,,te. Take a deep breath and clean the MAF gently and at the same time take care of the contacts too. Fuel consumption should go down to some 11-12 in a warm land like yours. Depending on the air filter the MAF should be cleaned every now and then...Of course many other faults can cause your problem....
what do u think can cause that too? but i have the maf never been cleaned.. shall i clean just the maf the sensor which have two tiny wire? or also the hollow of it? and what is the second reason for this playing? lambda sensor? can do that? today morning i was warming the engine and then i found it tooking 18 litre per 100 km at 1000 rpm so is that normal?Comment
You should do it step by step, to know which action solved your problem. Basically when you clean (rinse) the MAF, the housing is cleaned aswell, but be very careful not to injure the wire. Isopropilalcohol is usually used for the cleansing. The wire should be shiny at the end. Clean the contacts too. If all these doesn't work, you can look further. If it's the lambda probe, the VAG diagnostic tool should write the fault code out. Good luckOriginally posted by kniniowhat do u think can cause that too? but i have the maf never been cleaned.. shall i clean just the maf the sensor which have two tiny wire? or also the hollow of it? and what is the second reason for this playing? lambda sensor? can do that? today morning i was warming the engine and then i found it tooking 18 litre per 100 km at 1000 rpm so is that normal?Gabor
96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAFComment
Originally posted by horvathgYou should do it step by step, to know which action solved your problem. Basically when you clean (rinse) the MAF, the housing is cleaned aswell, but be very careful not to injure the wire. Isopropilalcohol is usually used for the cleansing. The wire should be shiny at the end. Clean the contacts too. If all these doesn't work, you can look further. If it's the lambda probe, the VAG diagnostic tool should write the fault code out. Good luck
allright my friend
the alchole is beside me now and just waiting till the evening to remove the maf. and submarge it in the alchole
and we will see , i will change the lambda sensor so or so cause it passed the 174km so propably its faulty right? , does bosh can give me cheaper price the vag for spare part?
Yes the Bosch is somehow less costly than the Audi shop one. Once more, very carefully with the MAF wire.Originally posted by kninioallright my friend
Gabor
Originally posted by horvathgYes the Bosch is somehow less costly than the Audi shop one. Once more, very carefully with the MAF wire.
hehe i will be carefull for the maf wire.. one more question is the Isopropyl alcohol the same as ethanol pure?Comment
heheheeh no, ethanol pure is better (to drink). basically ethanol pure would also do the job. The main thing is that your cleanser should leave no traace when its dry.Originally posted by kniniohehe i will be carefull for the maf wire.. one more question is the Isopropyl alcohol the same as ethanol pure?Gabor
Dont worry, ethanol is fine here. For some reason people don't waste alcohol for such measures, rather the IPA which is not for drinking. Unfortunately ethanol draws water when the bottle is opened so the so called "pure" word is not true for long....Originally posted by kninioi puted some ethanol at my skin and if the air blow on it , it disapears with out leaving any trace and it disapears very quick faster then bezine..Gabor
Originally posted by horvathgDont worry, ethanol is fine here. For some reason people don't waste alcohol for such measures, rather the IPA which is not for drinking. Unfortunately ethanol draws water when the bottle is opened so the so called "pure" word is not true for long....
aha then i didnt broke my maf
well that true what u said i forget the bottle opened and today it missed the almost the 30% from it
any way do u have the aby auxygen sensor part nomber??
