Maf Information Needed.
  • kninio
    • Aug 2004
    • 641
    • Home: Lebanon Current: United States
    is the mpg on the on bord computer take the signal from the maf? because its playning once 40 litre per 100 km in the citry drive and once 0.0 and mostly 20 litre is it a reason for a dirty maf? ill be thanksfull for any information about that!!
  • horvathg
    • Dec 2003
    • 556
    No. But dirty MAF can foul tha ECU and misleads the display. Also bad MAF cable contacts can do the same sh...,,te. Take a deep breath and clean the MAF gently and at the same time take care of the contacts too. Fuel consumption should go down to some 11-12 in a warm land like yours. Depending on the air filter the MAF should be cleaned every now and then...Of course many other faults can cause your problem....
    Gabor
    96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
    • kninio
      • Aug 2004
      • 641
      what do u think can cause that too? but i have the maf never been cleaned.. shall i clean just the maf the sensor which have two tiny wire? or also the hollow of it? and what is the second reason for this playing? lambda sensor? can do that? today morning i was warming the engine and then i found it tooking 18 litre per 100 km at 1000 rpm so is that normal?
      • horvathg
        • Dec 2003
        • 556
        You should do it step by step, to know which action solved your problem. Basically when you clean (rinse) the MAF, the housing is cleaned aswell, but be very careful not to injure the wire. Isopropilalcohol is usually used for the cleansing. The wire should be shiny at the end. Clean the contacts too. If all these doesn't work, you can look further. If it's the lambda probe, the VAG diagnostic tool should write the fault code out. Good luck
        Gabor
        • kninio
          • Aug 2004
          • 641
          allright my friend the alchole is beside me now and just waiting till the evening to remove the maf. and submarge it in the alchole and we will see , i will change the lambda sensor so or so cause it passed the 174km so propably its faulty right? , does bosh can give me cheaper price the vag for spare part?
          • horvathg
            • Dec 2003
            • 556
            Yes the Bosch is somehow less costly than the Audi shop one. Once more, very carefully with the MAF wire.
            Gabor
            • kninio
              • Aug 2004
              • 641
              hehe i will be carefull for the maf wire.. one more question is the Isopropyl alcohol the same as ethanol pure?
              • horvathg
                • Dec 2003
                • 556
                heheheeh no, ethanol pure is better (to drink). basically ethanol pure would also do the job. The main thing is that your cleanser should leave no traace when its dry.
                Gabor
                • kninio
                  • Aug 2004
                  • 641
                  i cleaned it with ethanol pure and its clean now enaugh and all it is brighting.. but now u tell me the main thing is that should leave no traace so u think ethanol pure left somthing or its ok now?
                  • kninio
                    • Aug 2004
                    • 641
                    you upset me now so do u think this ethanol pure will leave some trace :.( i did clean it very gently by tissue i roll the head of the tissue and smashed those thin wires then it shin good
                    • kninio
                      • Aug 2004
                      • 641
                      i puted some ethanol at my skin and if the air blow on it , it disapears with out leaving any trace and it disapears very quick faster then bezine.
                      • horvathg
                        • Dec 2003
                        • 556
                        i puted some ethanol at my skin and if the air blow on it , it disapears with out leaving any trace and it disapears very quick faster then bezine..
                        Dont worry, ethanol is fine here. For some reason people don't waste alcohol for such measures, rather the IPA which is not for drinking. Unfortunately ethanol draws water when the bottle is opened so the so called "pure" word is not true for long....
                        Gabor
                        • kninio
                          • Aug 2004
                          • 641
                          aha then i didnt broke my maf well that true what u said i forget the bottle opened and today it missed the almost the 30% from it any way do u have the aby auxygen sensor part nomber??
