Would appreciate some clarification of why the RS2 uses the different components and what exactly the differences are.
As we know the RS2 when timed with all its correct components ends up with the pulley mark one tooth to the left as opposed to the ABY/AAN lining up with the cam cover mark. Why is that?
We know the RS2 has an extra tooth on the cam belt.
We know the RS2 has a water pump with less teeth (26 vs 29 according to one source).
We know the RS2 has a different cam pulley.
Would also like to know whether the cam pulley only differs in the placement of the ignition rotor, being identical otherwise to the ABY/AAN.
