[Help]What sensor is this?
  • Cobra
    • Apr 2009
    • 78
    • Country: Portugal
    Hi!
    Just ended the job of a life...
    Got the ABY rebuilt and installed, just started the break-in process, and like the engine builder told me the engine is kind of sluggish
    Have got at the moment a rough/limp idle, when cold the car is very smooth idling, but when the rpm adjust to ~900rpm the idle oscilates, better, the whole car kind of shakes and the idle becomes kind of limp...
    Now the speedometer stoped at 0 and doesn't move at all, and I found this sensor disconnected...
    Where does this connect?
    Whats it for?
    Just trying to sort out the little problems so I can move on to GT2871 power!!!!
    Thanks for all the help!
    *95' Clio Williams
    *94' 19 16valve
    *94' S2 Avant
  • mcandmar
    • Apr 2004
    • 5118
    That would be a broken vehicle speed sensor..
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • Cobra
      • Apr 2009
      • 78
      • Country: Portugal
      Thanks mcandmar...
      Do you know where it would be connected on a ABY Avant?
      *95' Clio Williams
      *94' 19 16valve
      *94' S2 Avant
      • mcandmar
        • Apr 2004
        • 5118
        Just above the left front driveshaft on the gearbox.
          Originally posted by Cobra
          Thanks mcandmar...Do you know where it would be connected on a ABY Avant?
          As Mcandmar noted, on the front diff, intake manifold side of engine, as shown here:
